Sat, Feb 1, 7:21 PM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Feb 01 1:53 am)
Subject: what are JCM controls?
drawn ( ) posted Thu, 14 November 2024 at 10:08 PM · edited Sat, 01 February 2025 at 7:21 PM
Poser Manual freezes when I ask about JCM controls?
RedPhantom ( ) posted Fri, 15 November 2024 at 6:55 AM
Site Admin Online Now!
JMCs are joint controlled morphs. Don't feel too bad about not being able to see those 178 results. None are for JMCs and are results for just the word control. You would have to search joint controlled morph to get results.
JMCs are morphs that are linked to the bending of a body part to allow for better bending. If you look at how your own arm bends at the elbow, you'll see how the flesh compresses and pushes out to the sides as your forearm presses against your upper arm. With 3D, they would just intersect each other. JMCs are a way to tell it to act more like a real arm and move the flesh around rather than intersect. Modern figures are also weight mapped which is a way to do similar without the morphs but there are some limitations so JMCs are still used for the most realistic looking bends.
DeeceyArt ( ) posted Fri, 15 November 2024 at 7:57 AM
The results will also be more accurate if you put the search term in quotes.
"joint controlled morphs"
DeeceyArt ( ) posted Fri, 15 November 2024 at 8:03 AM
Can reproduce this. Will check into it.
DeeceyArt ( ) posted Fri, 15 November 2024 at 8:31 AM · edited Fri, 15 November 2024 at 8:31 AM
OK. The docs were recently updated. You will need to clear your browser cache and after that you should see search results correctly.
If you are using Google Chrome, clear the cache as follows:
There are three icons that appear to the right of the field where you enter URL or search term. The last icon is three vertical dots. Click that button. Then choose Delete Browsing Data.
On the next screen, a list of options will appear to clear out. By default all three are seleted to be cleared. Just accept the defaults and click the blue Delete Data button.
After that you should see the search work as it should.
drawn ( ) posted Fri, 15 November 2024 at 12:39 PM
ah-hah! a reaspmab;e explanation they were probably updating just when I tried to use it. Yay, Poser!
drawn ( ) posted Fri, 15 November 2024 at 12:42 PM
and  thanks, Red and DCA for explanations. JCM had me puzzled because in l'homme 2 it appears many times. Now, knowing, I won't be afraid to it
