Fri, Jan 31, 9:01 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Subject: Have to Use Materials Room to Pose
romangirl ( ) posted Wed, 11 December 2024 at 1:07 PM · edited Fri, 31 January 2025 at 8:56 AM
Little by little, Poser 11 is failing me.  I'm  nervous about reinstalling it for fear I might lose my files.
I no longer can make changes in the Pose Room. I have to constantly  go to the Materials Room to do anything.
Is there a fix...... or a safe way of reinstalling? Thank you!
romangirl ( ) posted Wed, 11 December 2024 at 1:08 PM
And where are general preferences?
Y-Phil ( ) posted Wed, 11 December 2024 at 1:17 PM · edited Wed, 11 December 2024 at 1:19 PM
Hi
"I no longer can make changes in the Pose Room" <-- that's a bit weird, I mean: if you can't see the Pose room, it may indicate a problem with the interface.
You can restore the original interface from the preferences
Then, once you have repositioned everything, use this:
Each dot represent a saved interface organization, it's a by room tool.
The general preferences respond to Ctrl-K under Windows. They are under the Edit menu:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
hborre ( ) posted Wed, 11 December 2024 at 2:15 PM
You commented that you can no longer use the Pose Room, could you elaborate further?  Y-Phil responded, speculating that you can no longer see the Pose Room.  If that is true, then he offered a solution.  Otherwise, clarify what your issue is.
DeeceyArt ( ) posted Wed, 11 December 2024 at 2:42 PM
Which version of Poser are you having issues with?  If Poser 11, make sure it's 11.3.
General Preferences is in the Edit menu in Windows. I can't find my power supply for my old Macbook, but it MIGHT be in the File menu on mac. I'm not sure.
romangirl ( ) posted Thu, 12 December 2024 at 10:29 AM
I can open and see the Pose Room figures.  But I have to go to the Materials Room to manipulate the figure.  Search and parameters are now in the Material Room instead of the Pose Room.
romangirl ( ) posted Thu, 12 December 2024 at 10:29 AM · edited Thu, 12 December 2024 at 10:30 AM
Thanks y'all for responding.  Working on it.  Poser 11.
RedPhantom ( ) posted Thu, 12 December 2024 at 12:25 PM
Site Admin
With the parameters pallet not showing, it might just have been closed or it might have been moved off screen. If it was just closed, you can reopen it here
If it is already checked but you can't see it, it was moved off-screen. You'll need to launch to factory state as recommended above
romangirl ( ) posted Thu, 12 December 2024 at 1:56 PM
I have the Pose Rom doing what its supposed to do.  Thanks so much, all!
Room.  Sorry.
