Wed, Jan 1, 5:29 PM CST
Renderosity Forums / Poser 13
Welcome to the Poser 13 Forum
(Last Updated: 2024 Dec 31 2:06 pm)
Subject: Show your Poser 13 renders!
odf ( ) posted Sat, 07 December 2024 at 4:10 PM
Y-Phil posted at 4:05 PM Sat, 7 December 2024 - #4491967
Ok, now that Poser implements a dedicated "Displacement node" for Cycles, it's now possible to have a second skin with visible thickness
Ooh, that's so neat! I'll have to try this.
Rhia474 ( ) posted Sat, 07 December 2024 at 10:47 PM
Once you guys have a method, would you please explain it to us mortals as well? Thank you!
midinick ( ) posted Tue, 10 December 2024 at 9:02 AM
I would like to know too :D I really like the snowlayers from Flink. But they are flat with superfly, I tried several setting.. nothing.. I got no displacement with cycles. I have no clue how to set for maybe 5cm high of snow o.O
hborre ( ) posted Tue, 10 December 2024 at 12:34 PM · edited Tue, 10 December 2024 at 12:34 PM
This is a quick setup using an architectural prop created for Firefly.  I added the CyclesSurface and PrincipledBsdf nodes for Superfly rendering.  Notice, the latest version of Poser 13 now includes a Displacement node.  Plug the Displacement map into the Height channel and adjust the scale.
The images below show Superfly renders without and with displacement.
hborre ( ) posted Tue, 10 December 2024 at 12:43 PM
The only modification I introduced into the shader was creating the Displacement map with increased contrast to darken the crevices and creases. Subdividing the mesh will improve the displacement quality, especially with organic figures or props.
Y-Phil ( ) posted Tue, 10 December 2024 at 3:50 PM · edited Tue, 10 December 2024 at 3:51 PM
Lol... HBorre's example made me thin to... Snarly's Snow Machine.
As it's still an old Python 2.7 script (yet...), I've launch that good old Poser 11 (remember? it's a portable program...), dropped some snow on a rock.
Then, I had to find the three essential nodes: SSMTheSnow, SSMBump and SSMDisplacement. The were only moved, no parameters changed, as it's just an experiment.
With an HDRi, it gives this:
Note the new Displacement node's scale: forced to 3 to have some snow on the almost vertical parts.
What do you think?
If there's some interest, I could port the script to Python 3.7
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
👿 Poser 13 and soon 14 ❤️
hborre ( ) posted Tue, 10 December 2024 at 4:31 PM
Sure.  That looks great!
Rhia474 ( ) posted Tue, 10 December 2024 at 5:52 PM
Definitely interested if you could port the snow script, sir!
Y-Phil ( ) posted Wed, 11 December 2024 at 9:48 AM · edited Wed, 11 December 2024 at 9:51 AM
Here you are: a Python 3.7 version of the snow machine. Its version is V3.0.0, and the name of the script differs from the original, to avoid any problem.
The Firefly part remains the same, the script has been adapted to the new environment, plus a few details, For example, it remains floating above Poser.
The advanced tab has one new parameter: the scale for the displacement node
You may download the Python file here:
https://kdrive.digital-paradize.com/app/share/116364/2a6289f5-2a0e-4d28-8531-a9eb36bf6c5d
I am of course opened to any suggestion to enhance it, as it relies on my mid-level knowledge of Poser's materials b5tdD13EirBrslM2Zi22GnJTXLncNwVZvB7I3fYn.gif
This year, the snow has a weird look, lol...
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
infinity10 ( ) posted Wed, 11 December 2024 at 10:40 AM
jancory posted at 1:42 PM Fri, 1 November 2024 - #4490925
infinity, this is an excellent LH morph, i might use him if he looked that good.
Sorry, just only read your comment - that's just the result of my mashing something up with the parameter dials for the figure... 😄😄
Eternal Hobbyist
Rhia474 ( ) posted Wed, 11 December 2024 at 12:42 PM
To change how a paid product 's script works you probably need to contact that vendor ( ie. Flink)?
hborre ( ) posted Wed, 11 December 2024 at 1:05 PM
You don't have a map plugged into the Displacement node.  Also, this is a paid product from a Rendo vendor, so you shouldn't post material room setups without permission.
midinick ( ) posted Wed, 11 December 2024 at 1:08 PM
hborre posted at 1:05 PM Wed, 11 December 2024 - #4492073
uh .. oh .. I will delete it, sorry, I had this not in mind
midinick ( ) posted Wed, 11 December 2024 at 1:09 PM
I cant edit it :( Can a moderator please delete it?
midinick ( ) posted Wed, 11 December 2024 at 1:46 PM
hm... I tried the snow machine script. first one was Displacement 3.0 and 2nd one is Displacement 10.0 (to see differences)
Well... it also made displacement for the whole figure, not just the layer :(
default settings 3.0
setting with 10.0
Y-Phil ( ) posted Wed, 11 December 2024 at 1:56 PM
midinick posted at 1:46 PM Wed, 11 December 2024 - #4492078
i have not changed the way the snow maker functions, I only add Cycles-based node at generation. it occurs material by material.
But in the first tab, there is an option that I have not explored:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
midinick ( ) posted Wed, 11 December 2024 at 2:29 PM
Maybe I expected too much snow. I made a new render. :D Anyway a very cool tool for landscaping, maybe not that much for figures with superfly :)
Superfly
Firefly
philadam ( ) posted Thu, 12 December 2024 at 10:25 PM · edited Thu, 12 December 2024 at 10:25 PM
When trying to use Snow machine 3 with all materials selected I get the above Error.
Any thoughts?
Y-Phil ( ) posted Fri, 13 December 2024 at 8:35 AM · edited Fri, 13 December 2024 at 8:36 AM
philadam posted at 10:25 PM Thu, 12 December 2024 - #4492122
Any thoughts?
It's not a part that I touched, but from what I can read,  the script by default looks for a PoserSurfaceNode.
I can reproduce this error if I delete  anything from the material, except a CyclesNode (activated for both render engines), same with a PhysicalSurface.
Even an empty material, based on PoserSurface, works.
This:
Gives this:
𝒫𝒽𝓎𝓁
(っ◔◡◔)っ
👿 Nas 10TB
midinick ( ) posted Fri, 13 December 2024 at 5:35 PM
Any thoughts?
Sometimes I got this message too, if I try again it will work fine. I have no clue why, but restarting the script was always my solution :)
Thalek ( ) posted Sat, 14 December 2024 at 9:18 PM
Y-Phil posted at 3:50 PM Tue, 10 December 2024 - #4492050
What do you think?
I'm a lowlands California boy, hence not much experience with snow.  WOULD the almost vertical parts have any snow on them?
RedPhantom ( ) posted Sun, 15 December 2024 at 7:50 AM
Site Admin Online Now!
Depending on the type snow, even fully vertical surfaces might have it on them. If it's wet enough and windy enough, you may find it covering road signs and sides of trees, cars, houses, etc.
midinick ( ) posted Sun, 15 December 2024 at 8:29 AM
Thalek posted at 9:18 PM Sat, 14 December 2024 - #4492144
If you mean in real life: yes it would. It is because of the wind... I think. I can even see it in the thin pillars of the street signs in winter. (forgive me please if I misunderstood your question)
weculativism ( ) posted Thu, 26 December 2024 at 11:48 AM · edited Thu, 26 December 2024 at 11:48 AM
Alien in meat suit
Alien in meat suit 2
weculativism ( ) posted Thu, 26 December 2024 at 11:50 AM
Alien shapeshifter in shapeshifter environment
weculativism ( ) posted Thu, 26 December 2024 at 11:52 AM · edited Thu, 26 December 2024 at 11:52 AM
Paul McCartney
weculativism ( ) posted Thu, 26 December 2024 at 11:53 AM · edited Thu, 26 December 2024 at 11:53 AM
Paul McCartney 2
weculativism ( ) posted Thu, 26 December 2024 at 11:54 AM
Paul McCartney 3
Paul McCartney 4
weculativism ( ) posted Thu, 26 December 2024 at 11:57 AM
Paul McCartney 5
GiveitUp ( ) posted Sun, 29 December 2024 at 12:06 PM
Angela Merkel ? ? ?
GiveitUp ( ) posted Sun, 29 December 2024 at 12:07 PM · edited Sun, 29 December 2024 at 12:07 PM
It has already started...
midinick ( ) posted Sun, 29 December 2024 at 1:49 PM
aww... the cute little cat guy is back :) LOL .. La Femme as doll.. very cool :D
karanta ( ) posted Mon, 30 December 2024 at 6:16 AM
JohnMichael posted at 4:32 PM Fri, 1 November 2024 - #4490928
Nelly. PP13 latest version using Firefly and good old V4. Leandro Hair. Some mods to the eye shadow and effects.
My Renderosity Store
karanta ( ) posted Mon, 30 December 2024 at 6:17 AM
To quick ;) wanted to add: Very beautiful render.
