Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Tried that. I can see the cirle for the item and can move that around but it just isn't there. I've rotated in all directions looking for it too. shrugs I thought it might have been because something was wrong with Vicky so I restarted Poser to start with a blank scene, clicked on the dress to "Add New Figure" and it's still invisible. I looked at the properties and it's checked for visibility.
no not the one in the librarys the one in geometries....mine is zygote clothingmilwombldress.rsr...what happens is poser loads this rsr file because it can load that faster than the obj, but if you delete it poser will just build a new one and the load will take a little longer while it does so....sorry c1rcle i disdn't realise you'd said the same thing i'm terrible for just replying without reading LOL......Steve PS while on the subject of RSR's NEVER EVER delete the one in the poser 4 folder named poser.rsr thats posers engine, the rest you can delete freely ;o)
yeah whatever you do don't delete poser.rsr I did once and had to reinstall poser, like steve says any other rsr file is ok to get rid of, I now get rid of all the rsr files in geometries once a month just to make sure, sounds like overkill but it stops the problems happening, Steve, you said it better than I did anyway :-)
Steve, that's a good tip, and I've never heard that before. Is that what usually has happened when something you've been using suddenly goes bad? I started using the Shania suit from poserworld in a sceene and after about a week of work on the file one day it told me 'can't load object' or somesuch message. I've been meaning to delete and reload the suit, but maybe I'll start by trashing the rsr in the geometry file.
Trying to put Vicky's dress (red one with long sleeves) on her and it doesn't appear? Is it corrupt? All the other clothing works so I'm terribly confused.
