Wed, Jan 8, 6:25 PM CST
Subject: ugh!!! .......
KimberlyC ( ) posted Sat, 03 November 2001 at 1:23 AM · edited Tue, 31 December 2024 at 4:52 PM
i can't seem to get my vikky maps to work...i've done the tut that ...i can't remember her name..but thank you smile....gave me...did it over and over....ack!!...sorry lol....can anyone give me any suggestions???
_____________________
.::That which does not kill us makes us stronger::.
-- Friedrich Nietzsche
ElectricAardvark ( ) posted Sat, 03 November 2001 at 1:39 AM
What exactly are you having trouble doing?
KimberlyC ( ) posted Sat, 03 November 2001 at 1:43 AM
adding the map to vikki...i go to materials...put the head map to skinhead .....then body map for the body....upperlids..and eye brows trans and the 2 transp. to 100%......i maybe forgetting something..but am i doing something wrong???? Thx!!! :)
thgeisel ( ) posted Sat, 03 November 2001 at 3:50 AM
sounds right, and what happens after rendering?dont they show up??
nfredman ( ) posted Sat, 03 November 2001 at 11:51 AM
There's a wee little check box that says, Apply to all materials, or something to that effect, in that Materials dialog--be careful about that one. You might want it checked when you apply the body material, then uncheck it before applying head, eyebrows, lips, etc. Otherwise you get weird patterns on the face!
KimberlyC ( ) posted Sat, 03 November 2001 at 1:01 PM
this is before i add the maps...
KimberlyC ( ) posted Sat, 03 November 2001 at 1:03 PM
and after....i've also got in my lib. the maps...you can apply...but whenever i apply them that way they don't go on vic that good...its like they need to be conformed...but when u do...it goes all weird...*smile*....maybe someone can see this..and know what i've done wrong..thx guys!
thgeisel ( ) posted Sat, 03 November 2001 at 2:22 PM
The probs are the eyebrows.In your material you have two eyebrows ,give them the normal headtexture and no transm. then there is one thing "upper eyebrows" add no transmap but set transmax and transmin both to 100%.that should fix it
KimberlyC ( ) posted Sat, 03 November 2001 at 2:27 PM
i didn't add the transm to either..thats y i'm so confused...and both are set to 100%
thgeisel ( ) posted Sat, 03 November 2001 at 2:43 PM
take one of the "eyebrows" make the color white and give it the headtexture,nothing else take second "eyebrows" make color white, add no map set transmax and trans min both to 100% than they are invisible. take "upper eyebrows" no map and transmax and min both to 100
KimberlyC ( ) posted Sat, 03 November 2001 at 2:52 PM
ok i think i see where i'm getting confused....their are 2 eyebrows...besides "upper eyebrows"?......is the second named differently..because i only see eyebrow and upper.... Thx!!
thgeisel ( ) posted Sat, 03 November 2001 at 3:06 PM
if you have viccy 2 you have 2 times "eyebrows" and one time " upper eyebrows" in the matlist
KimberlyC ( ) posted Sat, 03 November 2001 at 3:22 PM
hmmm....i have vicky 2 ...in the material list i have eyebrow and upper eyebrow.....ummmm....i'm confused....i'll take a look at the matlist
Crescent ( ) posted Sat, 03 November 2001 at 3:33 PM
Here's what I do: EyeBrows: Set to the same color as the rest of the SkinHead. Minimum Transparency to 0. Maximum Transparency to 0. No Transparency Map. UpperEyebrows: Set to the Object color you want. (For best results, set the ambient to Black.) Minimum Transparency to 0. Maximum Transparency to 100. Load a Vicki Eyebrow Transparency Map. My Victoria 2 has an extra EyeBrows listed at the bottom. Set it the same as the one at the top.
KimberlyC ( ) posted Sat, 03 November 2001 at 3:39 PM
i got it finally..Sigh....i dunno what i did different this time......starting to wonder if i made a boo boo and got vikky 1..dunno how i'd do that...but since i'm not seeing a second eyebrow...i'm starting to wonder.. Thank you to all that have helped me....i'm sure i was a pain :)~ Thx again!
nfredman ( ) posted Sat, 03 November 2001 at 6:51 PM
Don't forget the bump map... on the Eyebrows, add in the Head bump map you're using. No bump for UpperEyebrows, just transmap & a non-white color, as folks said above. Also, looks like you may have that default object color underneath the texture map. This is one way to give a pale Vicki a tan, but can be way too bright the way it is. Search Free Stuff for "nfredman" and download my Zap Vicki 2 Texture Pose file & install it. Use it before you apply a new texture. You may also want to create a non-textures V2 character for easy reference.
