Also, if you've previously saved figures already outfitted in clothes and/or morphs, you can IMPORT the .pz3 file. Just choose "import" from the file menu, and select "poser prop". It may look for .pz2 files or something like that by default, so just change the file options to display .pz3 or "all files." Hope that helps!
Everytime I try and add a new figure it says "Keep same porportions" with a little check box. That is it...and then it replaces the figure that I already have on my canvas. Whether you check the box or not. There is nothing under File, Edit, Figure, Object, Display, Render, Animation, or Window that says "Create New Character". And then at the base of the canvas, where it lists the Figures, sure enough the first figure is gone and is replaced by the second figure. [It will not list two figures at the same time] I am running Poser4.0... Thank you in advance for your time and help...it is most appreciated. *~Kimba
Hi, does anybody know, how to add another figure to a scene created with poser 4? For example, like two figures fighting? Thanks for help, over and out, Siegfried
