Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 03 8:59 am)
I see above that you are just getting MM4. If this is a V2 character, you will need to use a pose file and not a combined morph for each group. If it is a V1 character you should probably do it this way anyway. If you have non-DAZ morphs that you are combining, there is a way that you can apply these using the same pose file. If the character involves scaling, these settings can also be supplied using the same pose file. But for the head morph - if there is a combined morph component - you will be surprised just how small the file needs to be and still get the job done. My pardon, if you already know all this.
ive had mm4 for awhile and have used it before, but its on an archive disk right now (after installing XP Pro) so i figured it would be easier to just re-download it than search through all my cds (which are still in boxes anyways, since i moved 500km south last week). i made a combined morph for every body part, and the entire compressed cr2 is only 700k. the reason i didnt go the MAT file route is because she has a lot of scaling, and that info isnt stored in the MAT pose.
It may not be automatically stored, but it CAN be stored in a pose file. (MAT pose is a pose with Materials assignments.) This would be a MOR pose, if it had the dial settings. A MOR Donor pose if the actual combined morph deltas are stored there. A JNT pose if the scaling, or JP alterations or rotation/trans channel changes are stored there. And. These effects can all be combined into a single pose file. All you need is EditPad Lyte (or an equally transparent text editor.) I would be happy to show you and clarify anything that you do not quite see. You really will not believe how elegant this is.
