I haven't used the water dropplet program but I have played around with the fur-fur program some time ago which I believe is similar. As I recall you select the object you want to put droplets on and type "hair" (an undocumented poser function). Fiddle around with the settings, export the object and run it thru the droplet program...I think. The fur-fur program may be better documented and can probably give you some insight on how to use the droplet program. Hope that helps.
Sharen, Masa has developed some great utilities taking advantage of the hair easter egg in Poser to make fur and water droplets. Also he's the creator of MTMirror for morphs. You'll find his stuff and a few other items hosted for Yamato at http://www.eurus.dti.ne.jp/~masasi/ Poser++ is the name of his site :) Kalypso
I recently aquired the program from he "POSER ++" site to create water dropplets, the only problem is I don't get how you are suppoed to make dropplets into hair files so it can work. Does any one has a clue or am I clueless?
