Sat, Nov 30, 1:52 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Possible Poser Pro lighting problem?
Devon ( ) posted Mon, 05 November 2001 at 7:44 PM · edited Tue, 26 November 2024 at 6:45 PM
I was working with the Poser 4 Pro Pack FX and design book and was trying out some new lightning techniques, when I discovered that when I was asked to change the shadow map to 2.75 in the book I couldn't get it past 1.00. Is there something wrong here? I've been experiencing some major problems with my lights since I added those upgrade patches. What gives? Is there a problem still with Poser 4 Pro pack? How high should I be able to turn that dial to?
pjanak ( ) posted Mon, 05 November 2001 at 9:07 PM
Its strange but before you can adjust the shadow dial and have it "stick", you have to delete all the default lights in the scene and strat with new lights. Don't know why but such is the case.
Edgar ( ) posted Sat, 10 November 2001 at 3:11 PM
Maybe check the 'Max.' and 'Min.' settings for the shadow map. I say this because I've noticed that when I save a scene that has spot lights in it and then re-open it, alot of the 'Min.' and 'Max.' settings reset themselves to 1.00... This, of course, ruins all the work I've done, but...
Edgar ( ) posted Sat, 10 November 2001 at 3:12 PM
Devon ( ) posted Sat, 10 November 2001 at 9:44 PM
Attached Link: http://http://home.cfl.rr.com/greenhornet2002/
Thanks to all who have responded. It hepled out a lot. I forgot that I could doulble click on the dial and set it to what ever number I wanted. Your all a GREAT HELP. THANKS. I't people like you who make that forum so great. I can't thank you all enough. Happy rendering
