Tue, Feb 18, 4:21 PM CST
Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 7:53 am)
Subject: How can i render as a wireframe?
Raven82 ( ) posted Sun, 11 November 2001 at 7:56 AM ยท edited Tue, 18 February 2025 at 11:16 AM
I've only exported wireframes, and when i open them in Photoshop, they're, well, not rendered, so they don't look as good as they should. Anyone got a tip?
adh3d ( ) posted Sun, 11 November 2001 at 8:05 AM
I think if you select the display mode, and then you export the image(in the export menu), then the image is exported like show in the screen. I you wnat an antialias in wireframe, in the display menu you can select antialias document.
adh3d website
Raven82 ( ) posted Sun, 11 November 2001 at 9:10 AM
yeah, i tried that, but the edges get pointy and ugly in PS, but not in Poser.
praxis22 ( ) posted Sun, 11 November 2001 at 9:25 AM
Hi, You can simply antialias the image, (regardless of display mode) and then try to export that, it's under the same menu as "Render" but I don't have my laptop with me to check. later jb
shadowcat ( ) posted Sun, 11 November 2001 at 10:18 AM
when you are exporting the image are you using the highest quality? (where you name the image and save there is a little menu label "compression" at the bottom)
Raven82 ( ) posted Sun, 11 November 2001 at 10:21 AM
Shadow: No, i don't think I've seen that label... I'll check that out. thanx.
doozy ( ) posted Sun, 11 November 2001 at 11:33 AM
Sometimes I have seen renderings made by making a texture that shows the wireframe... start with the template (or the UVMapper output), fix up the template with Photoshop or something, then render with THAT template.
Raven82 ( ) posted Sun, 11 November 2001 at 12:56 PM
I'll try that, thanx.
wyrwulf ( ) posted Sun, 11 November 2001 at 1:26 PM
As doozy says, use the texture template as a transparency map, but you have to invert the black and white first (Nance's trick). You can also render a one frame animation using "Current Display Settings" and save it as an image file. You can use the animation render to make your render bigger than the display window. Change the foreground color to change the color of the mesh.
