Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2024 Nov 24 8:50 pm)
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
Well from the way I understand it, I've always been using box modelling. I use Lightwave (LW. Box modelling in the general term, is where you start out with a very basic shape (not always a box) and you cut, smoothshift(LW), and move points around building outward as you go, and then detailing. The Sub-D Surf that to a final model Bill Flemming (from what I've read in articles; one here even) draws the model in polygon's 1-dimensionally. Then he pulls those vertices out into 3D space. Kinda like if you took half your model and flattened the point values to 0 on one axis. Seems like a complicated way to go about it, and hard to get multi-limbed figures his way; without a lot of planning and welding, or to build things made for animation. Some people also use the per-polygon method. There are examples of that for LW owners in Dan Alban's books. This is where you build sections of a face poly by poly, then weld those sections together. Its good I think for areas that are going to ahve a lot of detail, and need a certain style of topology. I've used it before. ML
heyas; okay, cool. i'm glad i'm straightened out, now. ;) now don't knock bill flemmings' method, that's what i use. drawing the silhouette and pulling out points is not any 'weirder' than pulling points around on a box to make a shape. ;) i dunno, i find it easier to start with the shape and then build the geometry, than to start with the geometry and build the shape. ya know? i look at a box and i have no clue what to do with it ;)
heyas; i also prefer the add-on method of sculpting (molding in clay) rather than the subtractive method (chiseling, etc). if i started chiseling a block of marble, the best i'd end up with is a pile of marble chips. :) i confess, though, i HAVE box-modelled some things. i used it for the rabbit lure for my falconry gear (after all, that's basically a block of wood dressed in fur! lol!), and i even used it to sculpt the torso of my latest figure. a very SIMPLE figure. for stuff with detail.... i'd be lost.
I have a problem with the slicing method. Mainly that when you're dealing with complex models it's quite difficult to determine where you whould be creating the shape and where it should be positioned. But there are many objects that lend themselves to this extremely well! I guess that's why there are many different ways to create the same thing. What works for one, may not always work for the other. Jared
heyas; netwrksrf is... well, to me, its kinda like lofting in 2 directions at once. you build the horizontal and the vertical cross sections, and skin it. there's a tutorial on that at my goodie page. i think every program is kinda flaky about booleans. i tried to boolean union my glaucus body to its head, and that came out a TOTAL mess. (in lightwave.) but then again, i used a cone to cut the top off the daz jack o lantern and make a lid, and that came out splendidly. it depends on the meshes, i guess.
The term box modelling as stated by mallenlane is a term that is generally used. What is more acurate and one that is least understood and the proper is primative modelling. When take a primative ie: box, sphere, cylinder or cone and you build from it. Some software even include advance primatives such as the torus but that is not a universal convention. In programming, there are dozens of ways to perform a single task. Many of the conventions are preferential but to goal remains the same.
heyas; once upon a time i learned a method of building models in which you draw a top/front/side view on the walls of your workspace (or the backdrop) and use that as a guide to build your model. the tutorial author said it was 'bill flemming's box modeling technique.' so i thought box modeling is where you draw the silhouettes on a box around your model. but i have seen some 'box modeling' where you start with a box and subdivide, and sculpt the box, and THAT is called box modeling. ainnit? so which one is box modeling?
