Sun, Feb 2, 10:31 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Subject: Frustrating Problem - Exception Handler Error
whitemexican ( ) posted Fri, 16 November 2001 at 8:48 PM ยท edited Sun, 02 February 2025 at 10:24 PM
Caught C exception: exception access_violation trapped at 18f: 411d29 That is the message I am getting when ever I try to render using the High Res Maps. I have tried to modify the maps, add a scar to the face and tattoos to the body but it never renders. I get the message above and have to force quit Poser and then try again. Sometimes I get the error right away others when I try to render. I have created the character three different times. I have recreated the textures twice. Any ideas?
RyokoArt ( ) posted Fri, 16 November 2001 at 8:56 PM
Hey Whitey!! This means that you need to download and update the patch for Poser. You can get the Poser 4.03 patch at curiouslabs.com1 This will fix this problem and others Take care! Betsy
whitemexican ( ) posted Sat, 17 November 2001 at 4:43 PM
Alright did that. Now when I go to render the working window pops up and nothing else happens. The bar doesn't move and I can't stop it, I have to force quit. This is only when using the High Res Texture. 1ghz 512mb ram just so you know. The other problem is fixed however, thanks alot.
RyokoArt ( ) posted Sat, 17 November 2001 at 6:56 PM
Ok now this is a memory problem. Two things will cause this. So i will give both answers PC: if you are on a Win 98 or ME operating system, then Windows will only allot memomry upto a 128 block at a time. With current Poser version, the render still requests one block of memory, and for a high res texture it will need at least 300 mb of ram. So you may have 500 mb of RAM but if on 98 or ME, it can't be put to good use. The answer, upgrade to 2000. MAC: Change your memory allocation settings to Poser minimum 150000k and preferred 250000k. That will fix most problems but you may need to allocate more memory to it. Hope that helps. Betsy
Nance ( ) posted Sun, 18 November 2001 at 9:39 PM
SIDETRACK/OT (apologies WM!) [Betsy] "So you may have 500 Mb of RAM but if on 98 or ME, it can't be put to good use." Help! Might someone elaborate on that issue a bit further, or point me somewhere to get clued-in? I just helped a friend upgrade the RAM in his ME machine from 256Mb to 512Mb. Did we perform a pointless exercise? And, if so, how much RAM CAN be put to good use in W98 or ME? ...ok just re-read the above and now further confused. Betsy, are you saying that in 98 & ME, Poser can only use a maximum of 128Mb of memory?
RyokoArt ( ) posted Sun, 18 November 2001 at 10:40 PM
From what curious Labs has explained to me... yes. I talked to Mr. Hernadez at curious labs after alot of y customers were emailing me that they couldn't render high res maps on 98 or ME. Basically the way he explained the problem was that 98 and ME were programmically incapable of providing memory in one block at more than 128mb. For most programs this is now problem, most programs don't use that much ram at a time. However, Poser asks for lots of memory and all at one time for the dreaded render. Is there a work around? Other than upgrading to an NT kernel software... not that I know of. Betsy
whitemexican ( ) posted Sun, 18 November 2001 at 11:12 PM
I reduced the textures to half the size and it worked no problem. Thanks alot.
Nance ( ) posted Mon, 19 November 2001 at 11:24 AM
Thanks Betsy. I just realized who RoykoArt is and am delighted to see that you will still be hanging out here with us. Good luck on the new gig and thanks again for this and all your past help!
-Nance
