Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Oct 06 11:55 pm)
All is ok now. The problem were two: 1. I move some props after give them the parents. 2. Poser 4.0. qith poser 4 (metacreations), the parentship betwen props disapeare whe i save then in the library, with ten update to Poser 4.03 ( from curious labs), the parentship dont lose after save the props in the library. I import every prop ( obj) again and move them to the right position before apply the parentship. Thank for your replies.
I have a prop with some props like childs, Everything goes ok, but when i add to the library, when i open it from library, all the relationships have broken and all the props are in diferents places around the screen. When i add to the library i do next way: 1. Select the main prop ( the parent) 2. I select the subset ( in the pop up) all the props, the parent and the childs. 3. i add to the library What an i doing wrong? Help! thanks.
adh3d website
