Sun, Feb 9, 8:09 PM CST
Subject: Questions?
Bigballa111cmb ( ) posted Sat, 17 November 2001 at 11:54 AM · edited Thu, 06 February 2025 at 10:46 PM
Could I import a obj poser model into bryce.. tetxure it then export it back into poser. And is using a drawing as a greyscale and putting it into the terrian editor easer to model than boolean.
thgeisel ( ) posted Sat, 17 November 2001 at 2:37 PM
no, you cant texture an obj in bryce and get the textures to poser.only with terrains it works.The only possibility is to apply the texture in bryce to a plane,render the plane,save the image and use the image for the texturetemplate you get when you run your obj through uvmapper.
Bladesmith ( ) posted Sun, 18 November 2001 at 2:17 AM
Second question: yes and no...if you have a 2D program you're comfortable with you can make some fairly complex items in the terrain editor (Wappen's models come to mind). Both methods are useful, as are mixing the two.
