Wed, Nov 6, 9:38 AM CST
Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2024 Nov 03 9:18 pm)
Check out the
Subject: blends
Duga ( ) posted Sun, 18 November 2001 at 10:11 AM · edited Fri, 02 August 2024 at 5:35 AM
How od I smoothen the tail top?
Tephladon ( ) posted Sun, 18 November 2001 at 10:15 AM
Are us subdividing??? It looks like a cone shape at the top. I would knife the cone in half, delete the peak, then weld the existing points with their counter along the intersecting axis. That should smoothen things up. It is also much easier to diagnose if you post a wireframe or wire shade of the problem areas.
Duga ( ) posted Sun, 18 November 2001 at 12:55 PM
ok u're right, I should have used cone but did something else. Now I have the elipse, cone and fillet surface. by naming the post 'blends' I meant how do I sharpen the tail top. I have 1.1 there's no knife, so I'd appreciate some explanation.
The 4th Party ( ) posted Sun, 18 November 2001 at 1:04 PM
to repair the tip, you can split the tail, add a couple curves, and loft a new tip, hope that helps
Tephladon ( ) posted Sun, 18 November 2001 at 1:38 PM
Sorry Duga, I assumed you were using Lighwave. LOL You have to tell us what program you are using my friend or else we'll be lost trying to help you. It looks like you are using Rhino. I don't know that program
comastalker ( ) posted Tue, 20 November 2001 at 12:33 AM
The method, 4th party posted works well with rhino, just check it out.. cut the "problem zone" and create a new by lofting curves...
megazoic ( ) posted Tue, 27 November 2001 at 12:29 PM
i'm curious to know why 4th party split the tail vertically. couldn't produce same tip by using the horizontal spilt and lofting the continuous arcs from front to back? Any thoughts?
megazoic ( ) posted Tue, 27 November 2001 at 12:31 PM
scratch "continuous" from previous post, sorry!
