Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Feb 02 8:26 pm)
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
I used to work on miniguns in the military and I can tell u that the ammo is fed into the back section that little tube that sticks out of the side on your model it's called a feeder and ammo is fed in through that and into the bigger gun housing chambers the shot out the barrels. There is a chute that looks like a bunch of linked [_] Where the ammo is fed through. I know this may sound strange but if you need more then I can even give you some detailed pics too. I worked on many small arms including miniguns 50 cals m-9 ect....
Might try Jane's for reference photo's. The Jane's books are expensive, but most public libraries will have a full selection, and you can photocopy the images you need. Accurate firearms photos are a bit hard to find on the web for specific models at times - a lot of websites will only have views from one angle.
"I am a good person now and it feels... well, pretty much the same as I felt before (except that the headaches have gone away now that I'm not wearing control top pantyhose on my head anymore)"
the problem is: there are many weapons, u can hardly find. e.g. the h&k g11. It is the most accurate and powerful submashinegun on earth, because it uses 3,4mm ammo and 50shot mag. without any non-jack. it should be the standard-rifle for the german-army, but there were copyrightproblems (doesn't matter). The fact is, if you work hard, you'll probably find 2-3 pics on the inet.
Like I said... Library, Jane's "All the World's Small Arms". The 1986-87 volume [or maybe 88-89, too lazy to hit my bookshelf] has multiple views of the Hk G-11 caseless, much better detail than I've seen in net photos. [Actaully not the most powerfull in it's class - the 4.7mm caseless round it uses is a bit less punch than the 5.56mm, but it's more compact and allows a lot more rounds for the same weight and volume]
Yeah, more ergonomic overall. Still, no assault weapon can match the accuracy of a good scoped bolt action .223 [that's the 5.66mm in civies]. We're talking combat accuracy which is a completely differnt animal. Military rifles are designed to [hopefully] let a recruit put steel on target with a minumum amount of highly expensive training... Rate of fire on the G-11 is higher than any other comparable small arm until you get into the mini-gun class. Thing is like a 4.7mm buzzsaw at 2200 rounds per minute mean burst rate.
chuckle Nice... but I'd hated to of ever of been within a hundred meters of something THAT bright with hostile people shooting things in our direction. Can you just imagine the sun glinting off of that thing in jungle? ;0 GE M134? Earlier version of that's what they used to hang off of Cobra gunships. And still hang in a lot of helicopter door mounts in various parts of the world. I don't off the top of my head remember what the designation of the little 5.56mm version of that is.
