Fri, Jan 10, 4:31 AM CST
Subject: Please, help a new Poser's user
toniokitu ( ) posted Thu, 22 November 2001 at 10:09 AM ยท edited Fri, 10 January 2025 at 4:21 AM
I've a little problem with importing new characters from this site. When I've dl it, I extract it, the new character appears in the menu but when I click on it, there's nothing to do...
PhilC ( ) posted Thu, 22 November 2001 at 10:24 AM
Its possible that you do not have the associated OBJ (mesh) file that the character is based on. For example there are a number of items in the freestuff for the Victoria figure. If you do not own this figure then the file will not work.
c1rcle ( ) posted Thu, 22 November 2001 at 10:35 AM
silly question and totally obvious but are you just clicking on the picture or are you also clicking on the tick? to get the figure on either click the tick or double click the picture, just a thought :-)
Crescent ( ) posted Thu, 22 November 2001 at 10:45 AM
Can you give an example of a file you downloaded that doesn't work? It could help us track down the problem.
toniokitu ( ) posted Thu, 22 November 2001 at 11:23 AM
thanks for the responses. I've dl the character Angelyna
doozy ( ) posted Thu, 22 November 2001 at 12:58 PM
Click on it, then click the check-mark at the bottom? I'm only guessing what you are doing here...
Strangechilde ( ) posted Thu, 22 November 2001 at 10:19 PM
I too have downloaded that character and have had no difficulties, so, the file itself must be fine. When you start up Poser, you'll get the default guy unless you've changed the settings. Call up the 'figures' section where you've put the Angelyna character. Click on her. At the bottom of the library will be single ticks, double ticks, a plus sign, and a minus. You want to click on the single ticks: that's 'change figure', as it will tell you if you let the mouse malinger over the option. You'll get some options having to do with customized geometry just hit return; when you've learned mroe about the program, this will make sense. When you're installing characters, always attend carefully to the Readme file as you may need to place things in very specific locations for the figure to work!
c1rcle ( ) posted Fri, 23 November 2001 at 12:59 PM
good point strange, there's a lot of stuff out there that doesn't have any folder info anywhere in the archive, some not even in the readme, the first time I downloaded something like that I put everything in the same folder and poser threw a fit, needless to say it didn't stay on my harddrive for long. Before I get lynched by everyone it was a prop made back in early 2000, and it was the 1st and last I've seen by that person
kbade ( ) posted Sat, 24 November 2001 at 1:25 AM
I'm fairly sure PhilC had the answer. I think Angelyna requires that you already own the Victoria figure. Victoria doesn't come with Poser...she can be bought and downloaded at DAZ3D.
