Wed, Jan 8, 8:27 AM CST
Subject: Is this normal w/ trans maps?
Geekholder ( ) posted Mon, 13 December 1999 at 12:56 AM ยท edited Tue, 07 January 2025 at 9:51 AM
Is it normal for an object to become greyed out in the interactive display if a Transparency map is applied to it (for example, the pants in this image)? It makes it rather more difficult to work with and pose, as you lose all of the depth cues from the object. Is there a way to change this behavior in Poser, so that objects with transparency maps appear solid in the preview?
Ghostofmacbeth ( ) posted Mon, 13 December 1999 at 8:40 AM
I just had this problem last night ... but it only affected me when I was moving the camera and not in stationary form ... Rather annoying but yours would be much worse if it was on all the time. Never had it happen before though
arcady ( ) posted Mon, 13 December 1999 at 10:57 AM
I was just learning Trans Maps over the weekend (I'm new to poser folks) and this confused me to no end till I figured out it was ok in the renders despite looking all wrong in the work document. Problem was that it often looks the same in the work document even if you've miss set your trans mapping info. I had several renders that had a black shadow over the area that was supposed to be transparent. I eventually figured out how to set the dials. But it was a pain learning this when my preview didn't show any difference either way.
Truth has no value without backing by unfounded belief.
Renderosity Gallery
ScottK ( ) posted Mon, 13 December 1999 at 12:08 PM
Switching to another document display style can help. I usually use "smooth lined" which adds a visible wireframe, making posing easier. -ScottK
