Fri, Nov 15, 1:23 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: HAIR PROBLEMS!
SooPLeX ( ) posted Sat, 24 November 2001 at 10:30 AM ยท edited Thu, 14 November 2024 at 11:49 PM
Hey guys, whenever I try to put OOHBetty's spiky hair stuff in, it says A file has a new version number. Poser will try to read it anyway. Now i press ok, and then i do the conform thing, but then the hair tottaly makes my figure go into a thrusting motion, and it doesn't go on top of my character... can someone help?
dirk5027 ( ) posted Sat, 24 November 2001 at 11:15 AM
hi, just went into poser to be sure, but you can't "conform to" with the hair, remember it was made for smaller heads (kids) you'll have to play with the dials a bit to get it the size and positioned the way you want it
SooPLeX ( ) posted Sat, 24 November 2001 at 11:17 AM
ooo yea thnx
dirk5027 ( ) posted Sat, 24 November 2001 at 11:18 AM
OH P.S. to my last post did you get the update for poser? not the pro pack but just the update that will take away that error message although it should still work anyway
SooPLeX ( ) posted Sat, 24 November 2001 at 11:20 AM
oooo no. Where can I get it?
dirk5027 ( ) posted Sat, 24 November 2001 at 11:27 AM
oh wow..i had a hard time finding it myself just surfing around right now i'll go look for you if I can't find it i have it on cd i can send it to you
SooPLeX ( ) posted Sat, 24 November 2001 at 11:30 AM
Thnks a lot dude!
dirk5027 ( ) posted Sat, 24 November 2001 at 11:31 AM
http://www.curiouslabs.com/downloads/index.html poser 4 english updater found it quick and easy today, must be the caffeine
SooPLeX ( ) posted Sat, 24 November 2001 at 11:33 AM
THANK GOD I HAVE A CABLE MODEM!
melanie ( ) posted Sat, 24 November 2001 at 8:11 PM
I don't have this hair, but I would assume it's already pre-parented to the head and just needs to be repositioned and resized, or you might have to parent it to the head. Select the hair object, the click on Object and Properties, then parent to and select the head from the list. I don't know if this will help or not, but it couldn't hurt to give it a try. Melanie
Buddha32 ( ) posted Sun, 25 November 2001 at 10:12 AM
I have the OohBetty spikey hair and have had no problems. Dirk is right, the Poser updater from Curious will stop the error message. When using the hair, simply select the figure's head and then apply the hair object. It should pretty much go right in place on the head. Then use the dials to move it slightly if need be and be sure to parent it to the head with the object>change parent menu option.
