Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
I don't have this hair, but I would assume it's already pre-parented to the head and just needs to be repositioned and resized, or you might have to parent it to the head. Select the hair object, the click on Object and Properties, then parent to and select the head from the list. I don't know if this will help or not, but it couldn't hurt to give it a try. Melanie
I have the OohBetty spikey hair and have had no problems. Dirk is right, the Poser updater from Curious will stop the error message. When using the hair, simply select the figure's head and then apply the hair object. It should pretty much go right in place on the head. Then use the dials to move it slightly if need be and be sure to parent it to the head with the object>change parent menu option.
Hey guys, whenever I try to put OOHBetty's spiky hair stuff in, it says A file has a new version number. Poser will try to read it anyway. Now i press ok, and then i do the conform thing, but then the hair tottaly makes my figure go into a thrusting motion, and it doesn't go on top of my character... can someone help?
