Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:11 am)
Sounds like you need to turn off the inverse kinematics on the legs before you try bending it. Sometimes you'll encounter some really funny bending if you leave inverse kinematics on, especially when you have stuff like dresses conformed to the body. Go to the "figure" menu up at the top, go down to the "use inverse kinematics" option and uncheck the right leg and left leg, then try bending again. However, make sure you have the girl figure selected and not the dress selected when unchecking the inverse kinematics. That should solve your problem. Good luck. visualkinetics
