Thu, Jan 9, 12:56 PM CST
Subject: New Clothing/Transparency Question
John_Doe ( ) posted Tue, 27 November 2001 at 10:14 PM ยท edited Thu, 09 January 2025 at 2:52 AM
I have read several tutorials and am trying to make new clothing, but as yet I do not have (nor can I afford) any other 3d software. So I am stuck working with the clothes I already have and transparency maps. My present dilemma is this: I am trying to recreate the outfit used in the infamous "egyptian bikini" fight scene in The Mummy Returns for a Victoria model I have. I used the catuit as a base, trimmed off the parts I didn't need with Compose, and used a transparency map to get the right shape. Now I would like to be able to add a reflection map since the item is supposed to be gold, but transparency maps and reflection maps do not mix and I get the image shown below on the right. If I skip the reflection, I get the rather flat looking image on the left. What I'd like to know is: 1) Am I doing something wrong with the two maps or is impossible to have both a transparency and reflection at the same time? 2) Even better, is there a way I could shape the image itself and not have to rely on a transparency? Again, I only have Poser (and the Mac freeware available) to work with. I tried using the Grouping Tool to extract a prop, but since the item is in segments (left collar, right collar, etc.) that doesn't work. Thanks for listening.
Philodox ( ) posted Tue, 27 November 2001 at 10:32 PM
Try selecting both "multiply through lights" and "multiply through object color" under your reflection map and set your hightlight color to black... at least with me, that usually works....
melanie ( ) posted Wed, 28 November 2001 at 8:15 AM
Is the semi-transparent part supposed to show, or did you want that invisible? If so, make sure the falloff is set to 0%. I think that will cure the ghosting. Melanie
John_Doe ( ) posted Wed, 28 November 2001 at 9:54 AM
Philodox, that did it! I had tried everything else you guys suggested before, EXCEPT I must have missed turning both of those settings on. That's perfect. Thanks.
Philodox ( ) posted Wed, 28 November 2001 at 6:03 PM
Glad I could be of some help. :)
