Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
I use truespace a lot and the way I do things is I start with a plane and use a reference image behind it. I can add vertices to this plane and adjust them so the plane fits the 2D image one, then I bevel the plane and make sure it fits a side reference image. Is it possible to just add vertices to a plane in lightwave? The closest thing I've found is the knife tool but that doesn't do the same thing.
