I thought about putting links to Discrete and MilkShape3D but decided to leave them out. I don't know if Discrete will be happy with people using gmax for making Poser models. Who knows, maybe someone will make a Poser 4 gamepack?!...
And MilkShape3D costs about $20 (I think) ... It's been a couple of years since I bought mine. I think you can try it for free for a month - then you have to buy it to export anything.
Joat Mon
Attached Link: http://www.swissquake.ch/chumbalum-soft/
Yeah, MilkShape's only $20. I finally registered my copy a couple of weeks ago. It's intended for low-poly modeling and animation, but as long as you don't go over 16000 polygons, it works fine. MilkShape's perfect for doing Poser morphs, and you can convert to and from most popular 3D formats.For anyone who wants to check it out, the link's above.
Hi all, one question: what is Objaction Scalar (between max and poser).I have .obj import/exporter for max and work fine,but have some probems with scaling objects. Iterest thing is :when you export from poser one obj file and import in max ,do some on this object,than export from max and import in poser(wia phi file) scaling is good.But when I make brand new obj in max then import in poser(wia phi) they came in poser too big !I try to find solution in max exporter and change a num of scaling-down ,but they appeir in poser always big(same size) !? What I do wrong?Can that Obj Scaler help and where I can find that prog (or plug in)? Thermo Thans for tutorial,I just download,go to open zip...
I saved the the tutorial
as PDF using MAC OSX from IE 5.1
and printed it at work, so far it looks like THE MOST
Complete clothing tutorial i have ever seen!!
I will be using Cinema 4DXL or Lightwave for the modeling but i think i
might nail it this time!!
i am dying to make some custom outfits for my animated short film
many thanks.
I made a tutorial to teach my method of making clothes.
These are the tools demonstrated:
Poser 4
gmax
MilkShape3D
UV Mapper
detriang
It is basically for new people who want to make there own stuff.
And,
You can get it here:
http://home.att.net/~pmorris57/media/Clothing_Tutorial.zip
Joat Mon
