Thu, Jan 23, 12:19 PM CST
Subject: When you have named a bodypart wrongly...
brittmccary ( ) posted Tue, 04 December 2001 at 7:13 AM ยท edited Thu, 23 January 2025 at 12:10 PM
You're supposed to be able to rename it in the Hier menu in poser itself. I've tried that, - but no cigar. I called it lForearm instead of lForeArm :( I've tried everything, exept from starting from scratch. I've made the right groups in UVMapper, - it still seems to export the wrong group (I can't remove them there, can I?) but those groups are emtpy PHI builder receives the wrong names. And I have tried to rename them there, - with no success. They still turn up in Poser as rForearm :( What do I need to do to fix it? I shouldn't have to start all from the beginning and group the figure in UV-mapper? Should I?? Another quick question. The standard poses seem to NOT fit the kids. Am I correct in this assumption?? Thanks, Britt
Questor ( ) posted Tue, 04 December 2001 at 7:20 AM
You could edit the object file itself and insert the correct name then rebuild the figure.
Questor ( ) posted Tue, 04 December 2001 at 7:22 AM
You are correct in your poses assumption. This is because the mil kids are based on the millenium couple mesh (vic/Mike) and have extra joints. Standard poses will fit them, but some tweaking is needed.
brittmccary ( ) posted Tue, 04 December 2001 at 7:28 AM
Thank you, Questor. I'll get straight to it! :) I'm not using the millenium kids, - just the ordinary P4 kids. But it looks like it's the same with these, as it is for the mill kids. So I think I'll just pose them manually. When I do, - the clothings that I've conformed (with the right names for the body parts! lol) seem to fit. Britt
Questor ( ) posted Tue, 04 December 2001 at 10:01 AM
Sorry, I thought you meant the milbrats. The problem you might be having with standard poses on the ordinary p4 kids might be because of their actual size. The hip location is generally going to be different than with the larger p4 characters. Essentially though they use the same joint set up as the other characters but some of the zones differ. You should be able to apply a set pose and then just tweak it accordingly and turn IK off to reposition the hip so they're closer to the ground. There are a few pose sets for the P4 kids available around the net free, such as basic sports and suchlike. If you don't have them it might be worth poking around the freestuff areas and checking out Lannie's links list at 3dmodelworld
ScottA ( ) posted Tue, 04 December 2001 at 11:55 AM
Britt, Once you convert a .phi file you can't rename body parts like that. All you need to do is open the .obj file in UVmapper and select the body parts by group. The assign it to the correct name. And resave your .obj file. No need to mess with the mapping or the .crs, or anything else. That's all it should take. ScottA
ScottA ( ) posted Tue, 04 December 2001 at 11:57 AM
One more thing.... If you are using the Non-ProPack version. Don't forget to delete the geometries .rsr for that figure after you do that. Otherwise the changes won't take effect. ScottA
