Thu, Feb 13, 8:52 AM CST
Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Feb 13 4:12 am)
Check out the
Subject: small tutorial
TRAVISB ( ) posted Fri, 07 December 2001 at 7:15 PM · edited Thu, 13 February 2025 at 6:24 AM
just thought id show how i use bandsaw in a controlled way ! and one way to control vertice lines this should work in almost all apps just apply the tools that it uses
TRAVISB ( ) posted Fri, 07 December 2001 at 7:16 PM
1 . start with a box like above no biggie!
TRAVISB ( ) posted Fri, 07 December 2001 at 7:19 PM
2 select two poly's and hit the (f) key to flip there normals !
TRAVISB ( ) posted Fri, 07 December 2001 at 7:21 PM
3 . now use band saw on these two flipped poly's
TRAVISB ( ) posted Fri, 07 December 2001 at 7:22 PM
(above pic make sure the enable divide box IS selected !)
TRAVISB ( ) posted Fri, 07 December 2001 at 7:29 PM
it will slice them ! afterwards flip them back to face the correct way and do the same with the two poly's above (lshaped pattern ) 4. delete the poly at the base of the l shped pattern like here use the point tool to selct the three polys to make a tri
TRAVISB ( ) posted Fri, 07 December 2001 at 7:35 PM
now go to add point tool and add a point to the back of the tri on the left side to make it a 4 sided poly
TRAVISB ( ) posted Fri, 07 December 2001 at 7:38 PM
whoooa sorry about the size on that baby !! after you do this just use your point tool to make the other two quads hope you enjoyed this anyone that want sto translat the tools to other programs pleas do
