Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
I think it's linked to memory and not the Mike figure. I've had it happen several times, didn't matter what the figure was, and it was always after I had been using Poser for a long time without shutting it down, or had many characters, textures, bump maps in a scene. It used to freak me out, but i imagine if you just double-click on the head and set it to visible, it would solve it. Mike
I had a similar problem when loading (certain) multiple figures which turned out to be caused by something called "crosstalk" between Cr2's. There was a thread on it sometime back. While rebooting DOES work as a temporary fix, it's very depressing to work hard on a scene, load in that final figure, and be missing a head (or in my case, the hip/abdomen) Do a search on "crosstalk" and you'll find a solution for "just in case" it happens again... Starlok
My best advice is to save your work often, as a pz3 file. I've done some complicated work, and each time I made a signficant change, I saved a new version of the file: picture1, picture2, etc. That way if I couldn't proceed one way at least I hadn't lost the work I'd already done. More than once I was able to go back to the last good version, and take another approach.
