They are suppossed to be there. Though not like you have them. Right now you have a whole in her head it looks like since you tried to apply transparancy to the eyebrow material. There is nothing behind there so you see an actual hole. What youneed to do is on the "upper Brow" apply a transparancy map. On the normal eyebrow you simply need to make sure it is the same color as the skin.. Right now it appears you don't have any textures loaded so tht would leave her bald looking but with a texture it works.
Attached Link: http://ourworld.cs.com/posershadowcat/site/index.htm
Or if you prefer a tutorial on vicky (plus freebies)It's the Eyebrow that's causing the problem, however. It has the transparency applied where it shouldn't. I had this same problem when I first got Vicki 2. I figured it out just by experimenting with it I realized that, by putting 100% transparency on the Eyebrow, you're, in essence, drilling eyebrow shaped holes in her head. The upper eyebrows aren't the problem. Remove the transparency from the Eyebrow and the upper eyebrow will appear natural. Melanie
No, Brows Gone, just flattens them so they aren't raised from the face. The dark color you're seeing is actually a hole in the head created by transparency. Trust me. I had this problem and I cured it by turning off transparency in the Materials pallet to 0% Min and Max on the base Eyebrows, but leaving transparency at 100% Min and Max for the Upper Eyebrows. Melanie
"brows gone" does not flatten the eyebrows, what that morph does is pull the upper eyebrows into the head. the materials settings for the material labeled "eyebrows" should match "skinhead", "upper eybrows" should be transmapped think of the eyebrow as the skin beneath and the upper eyebrow as the hairs themselves.
Attached Link: http://home.teleport.com/~jonica/poser.html
And that's why you can't put transparency on the Eyebrows. You're, in essence, opening holes in her face and seeing the darkness of the inside of her head showing through. I've never used Eyebrows Gone on any of my characters. I never remember it's there, but the transparency is the whole problem. Transparency is used ONLY on the Upper Eyebrow. Zorares, give the transparency a try. It'll work. Check out my tutorial on my web site. MelanieThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
http://schuetzenpowder.com/sigs.jpg
