Community Center F.A.Q (Last Updated: 2024 Nov 29 5:48 am)
One thought that you could try.. once you are logged in.. select the Log Out option from the side-bar. This will remove the "old" cookie from your system. Then log in again, if it's a problem with the cookie, this should cure it. Also, the site is Case sensitive.. so if you have a mix of upper & lower case in your password.. :) HTH - James
The doctor says I have way too much blood in my caffeine system.
I'm having problems logging on. For a start I'm suddenly presented with a logon form instead of automatically getting in. Then my password is refused several times before it is accepted. I haven't altered my cookie. Any idea what's going on?
