Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Sep 17 7:30 pm)
I attempted to see if there where any entries on the P4 beta tester database on this but the server is down. Probably as a result of all the stuff going on at Meta. If I remember correctly, there where some issues about graphics card drivers and the amount to memory. If you haven't done it already, you might want to is if there are any updated drivers for your graphics card. The memory issues where directed more to the PC side then the MAC side. This is on a PC right? If so, how much memory do you have in it. I have heard other folks have had problems if they are close to the system requirements for P4. I'll keep checking on the database to see if comes back up till then there's not much more I can tell you on this.
You didn't, by any chance, install P4 directly over P3 did you? I understand that this is one of the main reasons for having P4 crash on start-up. At this point it may be worth while to save all your work (yes, I said "save your work" ;-p), de-install P4, remove the directories and make a clean install. There have been a couple of instances I've seen that solves these problems. Something has been nailed really bad so it's time for drastic action.
What is this error and is there a fix for it? It is happening constantly and I have a bad habit of getting absorbed and forgetting to save the work I have done. Any help aside from "Save more often" would be appreciated.
