Sun, Dec 1, 10:17 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 01 9:20 pm)
Subject: Question about posing and clothing
vervefx ( ) posted Sun, 16 December 2001 at 12:20 PM ยท edited Sat, 30 November 2024 at 6:09 PM
Hello everyone After I have put clothes on Vicki and try to pose, the clothes get all out of wack! I tried the RESTORE > ELEMENT but that often put cracks or tears in the clothing. I am supposed AFTER putting the clothes on, right ??? Thanks V
vervefx ( ) posted Sun, 16 December 2001 at 12:22 PM
I am supposed to pose after putting on the clothes..lol Thanks Again V
rodpanther ( ) posted Sun, 16 December 2001 at 12:47 PM
Usually if you add clothes they are a separate figure and you have to conform them first before posing. So load up your first figure ie the Vicki model, then add the clothes as a separate figure. Then select the clothes model from the menu just under the view screen and make sure the body is selected. for example Vicki Model is Figure 1, the clothes model is figure 2 etc. So seleclt Figure 2>Body then go to edit menu at top and conform to figure, select figure 1, the Vicky model and apply. The clothes should conform to the Vicky Model. Then when you go to Pose make sure Figure 1>Body is selected before you pose and select a Vicky pose and apply. The clothes should then stay conformed to Vicky and pose correctly. Sometimes they dont depending on the pose you use, so just keep experimenting. Hope this helps God Bless rodpanther
ronknights ( ) posted Sun, 16 December 2001 at 5:02 PM
Attached Link: http://www.ronknights.com/boots/index.htm
I made a tutorial earlier today about adding boots to a Poser figure. The same principle applies to adding any clothes. Check out the tutorial. Sometimes it's nice to see screenshots!
Strangechilde ( ) posted Sun, 16 December 2001 at 5:53 PM
I found with Vicky that sometimes it was easier to pose the figure before putting the clothes on her. They should conform okay, but you'll probably have to adjust them somewhat anyway.
vervefx ( ) posted Sun, 16 December 2001 at 7:00 PM
I'm trying to fit Vicki's boots but her leg parts keep cracking out. After searching the forum archives, I tried the "invisible feet and toes" method but the lower part of her shin is still a problem. Any suggestions? Thanks for your help V
Questor ( ) posted Sun, 16 December 2001 at 7:41 PM
If you're having problems with the lower part of the shin sticking through footwear and you don't need the feet visible, like for the default boots or those in the image above. Select each shin and use the "taper" dial. You shouldn't need to move the dial far for the shin to shrink inside the boots and disappear.
Valandar ( ) posted Sun, 16 December 2001 at 7:52 PM
Are those Vicky boots or Posette boots? Posette boots are designed to fit posette (the P4 nude woman), and may not work with Vicky.
Remember, kids! Napalm is Nature's Toothpaste!
vervefx ( ) posted Sun, 16 December 2001 at 7:59 PM
Valandar - They are Vicki boots. Questor - Thanks for the taper tip. I'm gonna give that a try. Thanks again V
