I have had nasty crashes when rendering anything larger than the screen size. For instance using "render to new window". Amazingly, I have been able to do larger renders by increasing my screen resolution to its maximum. Perhaps Windows allocates a lump of memory depending on the screen resolution?? Another "Ain't Poser wierd" fact, although I don't know how much this helps you!
Interesting! I upped my resolution to 1600 x 1200 and maxed the Poser view to 916 x 1185 and I am able to render in a new window (so far) at 2550 x 3300. It's a work around, not ideal, but it might work... (the Poser max view 916 x 1185 is still not high enough for print though, so I'm hoping that my renders in a new window will continue to work.... funny that it works when I have the VIEW maxed at 916 x 1185, but not when I have the VIEW at a lower resolution???).
If you run W2K make sure that the drive where you installed Poser is included in your virtual memory settings. Then you won't have the memory problem anymore. To do this, right-click on my computer, click properties, go to the advanced tab, click performance options. Then click on the change button. Include the drive where Poser lives. Give it sufficient space, minimum 2 x RAM and maximum 4 x RAM. After a restart you are out of problems. I did this when I had W2K. I did not have the problem in XP (yet). I did some large renders at 4000x2000, 2400dps. I must say that I have 512Mb Ram. Hope this helps.
I still get that often. You can up your virtial memory, but do NOT go over 3000, things go screwy then. I'm running windows 2000 pro with Poser Pro. 1gig of memory. This problem is never consistant. I can render a pic 2000 x 2000 one day, try again the next SAME pic, nothing changed and it won't do it. Visa versa, somedays I can't, come back later and it will. Poser HP has a bit on it, but their instructions for changing the memory thing is screwy. Made no sense to me.
Attached Link: http://www.shistudios.com
Ok, here it goes (for those who are having the problem)... REINSTALL the Poser 4.03 Updater. This seems to have made all the difference. EVERYTHING else more than checked out. Apparently an OS update (i.e. NT -> Win2k, Win2K -> XP) breaks the update somehow. I checked, double checked, and rechecked to make sure that I was running the update (4.03...) but decided to try reinstalling anyway... Let me know if this works for you guys. Happy Posing! JAB*I just saw yhis solution at another forum: After pulling my hair out over the "no more memory for rendering at this resolution" message and trying a lot of diffrent suggestions, none of which worked, I desided to isolate poser from everything else on my PC. I used Pation'omatic (which doesn't require reinstallation of any software afterwards) to make another drive (I allocated 10GB) and moved all my poser (software only) files to here, poser now runs as the only thing on this drive and renders my animations with no problems.... Simple but effective trick. Hope this works for someone else too. Trine Maybe this will do the trick!!
My Poser lives on it's own 40GB harddrive, I've reinstalled the patch (and Poser) after going to Win2K and I've changed the settings as mentioned before. Rendered out the image I wanted at 3200x3200 @ 300dpi. Closed Poser to get rid of all the damn textures loaded. Reopened Poser and went to render out another image with the same settings..."insufficient disk space..". On the up side, at least I got it to work once :) I haven't tried it since restarting my 'puter this morning so who knows what will happen today s
Attached Link: Shi Studios
I'm still trying to work through the "Insufficient disk space to render at the current resolution" error. I've upgraded from Win2K to XP... no change! To recap: The above error is an apparent bug in Poser that will not allow higher resolution renders (above about 600 x 600) in Win2K or XP. It is not completely consistent, I was able to render a few images last week at higher res but cannot anymore. The bug has nothing to do with systems specs (i.e. disk space, RAM, processor speed, or virtual memory). In any case (!), can anyone who has experience with this bug tell me if Poser Pro helps the situation at all??? VERY URGENT! thx! JAB*
