Fri, Jan 24, 11:23 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 9:54 am)
Subject: Need to make this Cage poserable
whitemexican ( ) posted Fri, 21 December 2001 at 10:28 AM ยท edited Fri, 17 January 2025 at 9:40 PM
I made this in Rhino, all the cells and door are individual and I want to make it so all the cells can swing open from one side, and the door can open as well. Can any one point me to a tutorial or give me some directions? Thanks in advance.
whisper ( ) posted Fri, 21 December 2001 at 10:38 AM
Attached Link: http://www.sams3d.com/Tutoral.htm
There's a great tutorial at Sams 3D
Whisper
igohigh ( ) posted Fri, 21 December 2001 at 11:54 AM
hmmm, looks like it can cage a Rhino...maybe a young dragon...or A Bunch Of Poser APES!! nice looking cage ;-)
Jaager ( ) posted Fri, 21 December 2001 at 1:15 PM
One way: Make everything that you want to move a separate prop. Import each one into Poser. If you parent each prop so that they are ultimately all joined, you can save them as a single prop file. The texture assignments can be a bit tedious with this method, but each sub can be altered using the Joint Editor and each axis moved to the logical location; then the rotation channels can be used for your movements and trans channels for sliding. Unwanted rotations can be locked at max/min = 0 and using EditPad, the unused channels made not to show.
themagi ( ) posted Fri, 21 December 2001 at 2:12 PM
looks like a "Hell In A Cell" Cage from the WWF.
whitemexican ( ) posted Fri, 21 December 2001 at 7:12 PM
Thanks guys, I will give it a try and let you know how I make out. Oh and it is made to be a Hell in a Cell but it can double as just an ordinary cage too.
whitemexican ( ) posted Thu, 27 December 2001 at 12:39 AM
Alright, I played around using the joint paramaters and have every section able to open in two ways, and the door swings open. If I save as one figure I lose all the joints and it becomes one solid figure instead of the individual parts. Props I would have to do all individually and I don't want to have people have to load 24 different parts for one steel cage. Can some one point me in the right direction?
