Glad you're back, and cool pic! It is lovely, Laurent, and the lighting is wonderful. My only quibble would be that the texture of the door and jam seems a bit too regular/repeating. Perhaps a larger image map would be better there. But I'll add that if you were anyone else, I wouldn't quibble about that minor detail because it still looks good. I only mention it because I know you devote so much attention to the textures (along with composition, lighting, etx.) And too, if I look at it another way, I don't see any problem with it at all. So...lol, ignore this! ;D Happy Holidays!
Thanks all :) Varian... I don't have many wood textures that look old and look good from a close view. I used the 'bark' texture but it required some tweaking. This one is a procedural texture. And don't worry about the comments. That is exactly what I am looking for :)
Thanks for the comment Alekssander. I agree the hands can be re-done, as the flat leaves above the door. But I don't see what you mean by a 'stream of light through the opening'. Are you saying the sunlight should shine more inside of the house ? Actually, I am not satisfied with that opening. By experience, I know it should look much darker, almost pitch black, because of the contrast between the shadows inside and the brightness of the sunlight. I'll work on that too...
I got a little bit of problem, tryinbg to understand what you are making. The hole scene looks a bit strange. Even when sunshine conly comes from one dirrection, let's say south, you would still get lights through windows in the north. If the room inside, don't have avy lights or windows. You would get a stream of light from the opening, hitting the furnitures on the inside.At the moment, it looks like there is moonlight inside, but sunshine outside. As you suggest, it should have been darker inside, but with a stream of light from the opening, breaking up the darkness. Since there are a lot of realy good details on the girl and her clothing, the wall outside and the flowers. The door and the furnitures innside looks "cheap". Some more details, such as a better handle, maybe a lock and some cracks. Would make it more real. The cabinet, that seems to be ?, and then blue because of the shadow, have a strange texture on the inside of it. It is aslo strangly low compared with the girl. Maybe som other taller solution would have been better, or maybe somekind of clothhanger. If you can get a texture of old furniture painting, it would look even better.
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=119184&Start=1&Artist=agiel&ByArtist=Yes
![file_248961.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_248961.jpg)
After two months of break (one of which was spent turning my christmas present into a usable machine :) ), I can finally return to this forum. This image seems appropriate for this occasion. I was working on a different idea but this one turned out so nice that I decided to keep it. One observation - working with additional lights and exposure settings in the atmosphere made a world of difference for this scene. I hope you will like it.
