Thu, Nov 14, 7:40 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: Poser3 export as obj ??
zspider ( ) posted Wed, 26 December 2001 at 8:29 AM ยท edited Sat, 10 August 2024 at 2:03 AM
hello,
i've got a magazine copy of poser3 and i'm trying to
export as obj with the "export object groups for each
body part" selected. a conversion utility from poser
to povray states that this should produce both an obj
and an mtl file, but i'm not getting the mtl file. is
the mtl file a new feature of poser4? can i produce
the mtl file using poser3?
thank you, miker
Nance ( ) posted Wed, 26 December 2001 at 6:05 PM
Attached Link: http://www.uvmapper.com
Brain-clouds here perhaps. I didn't think Poser would create a .mtl file, in 3 or 4. You can, however, create a .mtl file after you export it from Poser by running the .obj through Steve Cox's "UVMapper" and saving it again. uvmapper.com
zspider ( ) posted Thu, 27 December 2001 at 6:01 AM
hi nance, thanks! i'll give that a try. posts on other bulletins seem to indicate that the mtl export as object came with poser4. thanks again, miker
Nance ( ) posted Thu, 27 December 2001 at 10:05 PM
Attached Link: http://www.us.righthemisphere.com/products/3dexplore/index.htm
Hey, my mistake, wrong app. I was confusing the UVMapper export dialog with the 3D-Exploration export dialog. It is 3D-Exploration that will save a .mtl file with an .obj file, not UVMapper. There is a full function 30 day demo at: http://www.us.righthemisphere.com/products/3dexplore/index.htm
dwilmes ( ) posted Thu, 27 December 2001 at 10:33 PM
VueMaster will make a MTL file for you, as well as a number of other things having to do with exporting from Poser for other apps. Dan http://www.zenwareonline.com for VueMaster, CR2Edit and the rest of the Zenware graphics line
