Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
Phillip are you on? Is it possible (without putting you through to much trouble) to make the waist just a bit longer - just to or right below the belly button and a bit 'looser' (is there such a word)? I played with the Y dial but the top only kept going way above the collar. Thanks for this much though!
I'd like to create a crossing guard vest for Vicky2. The only clothing item for any Poser figure that would look correct with this texture happens to be the P4 female. I unfortunately purchased the P4 female - Vic2 clothing pak from the3dwizard not realizing the one item I desperately needed converted, the P4 female vest, was not included. Any one out there have any suggestions what else I could do? I have Rhino 2 and could probably create a vest, but I have no idea how to make it conforming. I just spent the last two hours creating a texture, trans, and bump map for Vic2 Tshirt, but it looked like crap when rendered. Even with the trans map it looked outta proportion. Thanks Dave K.
