Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 11:01 pm)
Download P3dO Explorer from freestuff. It has a png2rsr utility. The 'Newer version than expected...' is because you are loading a ProPack created file in Poser 4. Just click OK and it should load fine.
If you want to have exactly the same file in *.rsr format, this is one of the possible solutions. Just convert the .png file in Photoshop to a PICT file (.pct). After that convert the *.pct file with the RSR Converter (sarch for "RSR-converter" in the Free Stuff area). Your problem with the version number. Open the *.cr2 file with an texteditor (e.g. notepad) and replace the string "number 4.3" with "number 4.01".
Thanks Everyone I downloaded the P3do utility and the rsr files are there now. I do have another question though. What exactly are the version numbers in the cr2 files? Are they version numbers of the program? THe cr2 file for the bikini says "number 4.2". I should change this to "number 4.01" to stop does error messages. I'll change those as the bikini still isn't loading right or I just don't know what I'm doing. Hmmm..possibly a bit of both :) Thanks Again V
I just downloaded and unzipped the real bikini into their proper folders only I don't have any icons for the files just the guy shrugging his shoulders. That because of the missing rsr file, right! Hmmm...is there a way to make them or convert the png files to rsr? Also, when I tried to use them I got an error message that said version number was lower than expected or something like that. Anyone know what that means? Poser version 4.0.3 Win 98 Thanks V
