Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Oct 06 11:55 pm)
If you use the "change figure" (1 check mark) button,
your figure will load with the pose of the previous figure.
If you use the "create new figure" (2 check marks) button,
your figure will load with the pose that you saved it with.
Then select the "old" (previous) figure and "delete" it (if you want to).
cheers,
dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
I select a charactor from the library and pose it the way I want now how do I get the charactor to open in that pose automatically ...I tried saving it back to the library but it opens in the previous pose instead of the new one... Is there a way to do this or do I have to use the memory dots...I would like the new posed charactor to be the default when I select it instead of reposing or starting from the default pose??????????? Thanks
