It looks like the X trans is too positive on the right eye and too negative on the left. Select the right eye - d ch on the Xtrans slider and see what the menu shows. The menu will use values to the fourth place, but will only show values to the third, and will round the value it uses for the display. i.e. If you type in 0.0006, it will use 0.0006, but it will say that the value is 0.001
All body pose files have trans as well as rot settings. If the pose was made on a figure with eye at zero, it resets the eye location. Almost all poses are zero for all three eye trans. You must lock the channel if you want to keep any other value. The eye trans are necessary, the hip trans is also. The others = ? I just made a JNT.pz2 for my use that set the min/max for all the other trans channels to zero. My hand fix for V1 did the digits, I just made another to include everything but the eyes and hip (and not BODY).
