Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Good point on the wrinkles. I made the texture from cloning the heck out of a pict of a leather thing from a lingere catalog :) I think I can pull the fold lines so they hug the shape of the body more in PhotoShop, maybe get some more samples and feather them in ;) The wrinkles on this were pure bump map. I was trying to keep the mesh as smooth as possible so that I can use it for a bunch of different styled outfits later, but using Amorphium is a great idea. Thanks Cody! -Trav
Man I gotta get me a 3D object maker... Too many ideas and Poser just can't do them all... Do pretty much all the object modellers allow you to base the shape of one object off of another? So that you could easily shape the dress or other item to mostly match the figure?
Truth has no value without backing by unfounded belief.
Renderosity
Gallery
Arcady: I haven't found one yet that will do it easily. The process is a little drawn out. You have to make a series of contour lines (mainly by hand) around the body. I am stuck on making dresses because I am still working out some bugs with my process when it comes time to add arms or legs to an outfit :) Then you have to split the mesh, UV map it, group the materials, and then do the joints :) -Trav
