Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 3:20 pm)
Re: bump maps - it doesn't matter because the "slider" allows for -100% to +100%, so you can adjust the "bumps" up or down without changing your .bum (;=]).
Re: trans maps - WHITE areas WILL allow tex to SHOW
BLACK are masked (WILL NOT SHOW)
Hint: if you have ANY "highlight" (< 0%) on a transmapped item, the item WILL NOT be totally masked. That is, the highlighted area will still show up when rendered.
cheers,
dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
I am confused. on a bump map , is it white croma = raised bump and black croma = depressed ? lighting is playing havoc on me and thus my confusion. and in a trans map the white croma = that which becomes transparent right ?! Many thanks in advance!
