Tue, Dec 24, 11:19 PM CST
Subject: the poser 4 patch is out
viper ( ) posted Sat, 25 December 1999 at 7:37 PM · edited Tue, 24 December 2024 at 11:15 PM
the poser 4 patch is out here is the url http://host-1.ghosteffects.com/poser/patch/patch.html
Cage ( ) posted Sat, 25 December 1999 at 8:20 PM
I haven't installed the patch yet. Is it worth the trouble? Does it fix everything it promises? What precautions should I take with my files before putting it into place?
tmech ( ) posted Sat, 25 December 1999 at 8:43 PM
I installed the patch. It works fine. Haven't tried all the fixes but it seems stable. Follow the install instructions on the link page. The only thing that seemed a little odd is that after after reboot, the 'prefs' for 600 x 800 (that I use) didn't display all the UI interface utilities. To correct, I deleted the pref file for 600 x 800 that had been created in the last shutdown. Poser created another pref (600 x 800) the next time I ran the app and all is fine - and stable. I would recommend installing it.
Traveler ( ) posted Sat, 25 December 1999 at 9:14 PM
Its all that is says that it is, except for the catsuit fix, didn't see that in the zip file, but I never thought it had any problems anyways. Definatly give it a go, but I would back up the stuff that you replace just incase. -Trav
viper ( ) posted Sat, 25 December 1999 at 10:01 PM
yes is great I can start useing bryce again with my poser characters
picnic ( ) posted Sun, 26 December 1999 at 8:10 AM
A question--I have not dl'ed the patch yet but now have some time to do it. I understand the readme is quite thorough, but I'm wondering if I understand that all the PZ3, libraries, etc. come through unscathed? I do know they should be backed up, but are most seeing everything stay 'as is'? Diane B
viper ( ) posted Sun, 26 December 1999 at 12:27 PM
I did not back up anything (which may have been stupid)and have had not problems with anything running yet.
nerd ( ) posted Sun, 26 December 1999 at 4:32 PM
Forum Moderator
I put the patch on. Ive been able to run Poser for hours without a single (Ding) Caught Exception 4Q2:OU812. I even moved joint rotation orders twice in a row. I created more than one figure in a session. I imported a huge OBJ model. Then, Then I exited the program, NORMALLY! WOW!
Nance ( ) posted Mon, 27 December 1999 at 8:07 AM
Picnic - Nothing get erased, just a few files replaced with newer ones. Mostly program files rather than libraries. The only Figures that get changed are the base .OBJ files in the Geometries folders for Nude Male, Nude Infant, and the Snake but you will still be able to open your existing .CR2's based on these figures.
picnic ( ) posted Mon, 27 December 1999 at 9:42 AM
Thanks all. I meant to dl it last night but forgot. Has anyone tried exporting to Bryce yet? That is my biggest issue--probably not a big issue with most of you. However, Viper, since you are using Bryce--what is different in regards to that please? Diane B
