Mon, Feb 10, 8:08 PM CST
Subject: Poser to Vue question
tradivoro ( ) posted Thu, 17 January 2002 at 11:20 PM ยท edited Fri, 10 January 2025 at 4:11 AM
Ok, so I imported the P4 man into Vue... It's not terrible, but looks not as good as in Poser.. But what I see is a problem is that the eyes, the white eyes, seem to be sunk in, whereas in poser, they are right up against the lids.. Is this something you folks run into???
Varian ( ) posted Thu, 17 January 2002 at 11:43 PM
Hm, I haven't heard of that one yet. Maybe it's related to the angle of the lighting or the degree of ambiance (ambiance is pretty high in Poser). How about post an image to show us what you mean? :)
MikeJ ( ) posted Fri, 18 January 2002 at 4:40 AM
I've noticed that every now and then for no apparent reason Vue will botch an import, and body parts can be out of place. Just try it again. Anyway, at least the Dork's eyes are separate objects and can be moved, in both Poser and in Vue.
tradivoro ( ) posted Fri, 18 January 2002 at 8:14 AM
Thanks Varian and mike.. Yeah, I tried to move it, but if I used the cursor, it moved too much and unless I ungrouped the character, I couldn't get the parameters of the eye to appear in that parameter box on the right... so I figured, let me ask.. I'll try re-importing and see what happened... also, try to change the ambient light settings...
Varian ( ) posted Fri, 18 January 2002 at 9:17 AM
If you still have a problem, show us a picture. It'll be easier to troubleshoot. :)
tradivoro ( ) posted Fri, 18 January 2002 at 12:13 PM
Oh absolutely, let's see what happens tonite...
Scytale ( ) posted Fri, 18 January 2002 at 12:28 PM
When I want to import Poser scenes into Vue, it says that my Poser Serial number isn't a valid one.. but it works with Poser itself.. Very strange isn't it ?
MikeJ ( ) posted Fri, 18 January 2002 at 12:44 PM
Scytale, That's just "one of those things.." It's a Vue problem, not a Poser problem. Try this: Find your poser.exe file in the Poser root folder, and rename it to poser.exe. That's not a typo---just rename it to the same thing. It won't affect Poser any, and it will probably end the problem. Also, you can't have Poser running while you try to import a PZ3 file into Vue. If that doesn't work, try reinstalling Vue afterwards. Don't uninstall it first, just reinstall it. Let us know if it works or not.
tradivoro ( ) posted Sat, 19 January 2002 at 1:19 PM
The solution is replace the blasted texture that comes from Poser and put on one that's actually designed to look human as opposed to the manequinn look of Poser out fo the box... :) Foruntately, some people have provided free textures for alternatives in poser, so that made it a lot better.. So, although the eyes still look a little funky, the new texture makes up for that...
nathany ( ) posted Sat, 19 January 2002 at 7:50 PM
Notes: - Vue has an option to scale objects on import, which maybe could mess it up. - Shift+nudge will nudge less
tradivoro ( ) posted Sat, 19 January 2002 at 10:10 PM
WEll, I'll look into that nathany,thanks...
