Mon, Dec 23, 1:20 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 23 1:20 pm)
Subject: GREENSCREEN in POSER?
ETHAN1 ( ) posted Sat, 19 January 2002 at 4:54 AM · edited Mon, 23 December 2024 at 12:55 PM
Hi yall, I have a question. I want to create a 3d/real movie. For this I must the poser figure and animation with a invisible background. I thought I create a greenscreen in poser and delete the key color with adobe premiere. Anybody ever tried that? does it work? Thank you!
Mazak ( ) posted Sat, 19 January 2002 at 5:17 AM
Save your Poser pictures in TIF format, the TIF format has a alpha mask. Mazak
Google+ Bodo Nittel
ETHAN1 ( ) posted Sat, 19 January 2002 at 5:27 AM
cool! But what if I want to create a animation avi?
Mazak ( ) posted Sat, 19 January 2002 at 6:06 AM
Select in Poser: Animation > Make Movie... Sequence Type: Image Files (TIF). Render your animation. Load the image sequence in adobe premiere. How to make a movie in adobe premiere read the manual.
Mazak
Google+ Bodo Nittel
ETHAN1 ( ) posted Sat, 19 January 2002 at 6:11 AM
THANKS a lot Mazak!!! Will post my vid her when its finshed :)
Mazak ( ) posted Sat, 19 January 2002 at 6:16 AM
Attached Link: http://home.t-online.de/home/bnittel/mazak/animationen.htm
You are very welcome :) See also my Poser animations. Mazak
Google+ Bodo Nittel
ETHAN1 ( ) posted Sat, 19 January 2002 at 7:21 AM
great Work!!!!!!!!!!
welcomesite ( ) posted Sat, 19 January 2002 at 7:44 AM
Attached Link: http://welcomesite.com/c4dhelp
There is one problem. When you save a sequence of images in Poser, Poser 'inverts' the images. Supposedly you can 're-invert' these in a program such as Photoshop, although it will not work for me. What I was forced to do was 'manually' render each frame of my animation as a single frame, I then move the timeframe forward one frame and render the next frame. This was not an efficient solution, especially with animations over 30 frames. I now no longer render in Poser, I import my animations into Cinema4D and render them there, with no 'inversion' problems.
Mazak ( ) posted Sat, 19 January 2002 at 8:34 AM
This stupid program!! Poser 'inverts' the Alpha mask. I always save my animations as Image sequence. So I have more control over the MPEG quality. I had never such problems. Thank you for the info. Mazak
Google+ Bodo Nittel
ScottA ( ) posted Sat, 19 January 2002 at 12:47 PM
I use Ulead MediaStudioPro. But I believe that Premiere can cromakey an .avi background. Just render your .avi uncompressed with a solid background color (usually blue or green). Then cromakey by color in Premiere. ScottA
VirtualSite ( ) posted Sat, 19 January 2002 at 12:54 PM
Import your .avi and use it as a background animation. Then you can either "make movie" as an animation or as a series of images, and Poser will blend everything really nicely.
