Mazak
Attached Link: http://home.t-online.de/home/bnittel/mazak/animationen.htm
You are very welcome :) See also my Poser animations. MazakAttached Link: http://welcomesite.com/c4dhelp
There is one problem. When you save a sequence of images in Poser, Poser 'inverts' the images. Supposedly you can 're-invert' these in a program such as Photoshop, although it will not work for me. What I was forced to do was 'manually' render each frame of my animation as a single frame, I then move the timeframe forward one frame and render the next frame. This was not an efficient solution, especially with animations over 30 frames. I now no longer render in Poser, I import my animations into Cinema4D and render them there, with no 'inversion' problems.This stupid program!! Poser 'inverts' the Alpha mask. I always save my animations as Image sequence. So I have more control over the MPEG quality. I had never such problems. Thank you for the info. Mazak
Hi yall, I have a question. I want to create a 3d/real movie. For this I must the poser figure and animation with a invisible background. I thought I create a greenscreen in poser and delete the key color with adobe premiere. Anybody ever tried that? does it work? Thank you!
