Fri, Nov 22, 11:49 PM CST
Subject: Help with poser please.
BigKabuto ( ) posted Sun, 20 January 2002 at 12:32 PM ยท edited Fri, 22 November 2024 at 8:24 PM
I have made an Allied Soldier figure in Poser4, the helmet is an obj file...i want to have the helmet parent with the head of the male figure..but it doesnt work..when i move the head around the helmet is not stuck on it...and i want it to be stuck on the head so whenever i move the character so will the helmet...help please
PhilC ( ) posted Sun, 20 January 2002 at 12:51 PM
Select the helmet and go to Object/change parent. In the popup window select the figure's head (ensure that you do not mistakenly select the clothing). Click the "OK" and the helmet should now stay with the figure.
BigKabuto ( ) posted Sun, 20 January 2002 at 1:04 PM
nope still doesn't work...could you try it out? make a simple male figure in poser4, insert the obj helmet you can find it on free stuff..just type helmet..it's the green soldier helmet..
Little_Dragon ( ) posted Sun, 20 January 2002 at 4:34 PM
PhilC's method works for me. Maybe this will work, instead. Select the helmet. Go to the Object menu and select Properties. Click the Set Parent button and choose the figure's head from the popup window. Click OK. Now try moving the head.
BigKabuto ( ) posted Sun, 20 January 2002 at 4:37 PM
very weird , normally it would always work...but it just doesn't
stewer ( ) posted Sun, 20 January 2002 at 7:26 PM
You can also change parenting in the Hierarchy Editor, try it there.
doozy ( ) posted Mon, 21 January 2002 at 12:58 PM
You can find it on free stuff ?? Searched "allied" nothing found. Searched "helmet", many found but not that one. Searched "bigkabuto" nothing found.
BigKabuto ( ) posted Mon, 21 January 2002 at 1:42 PM
I didn't make the helmet, but just download this one..search helmet Helmet for G.I.Joe by Rexxzilla
Little_Dragon ( ) posted Mon, 21 January 2002 at 7:48 PM
Found it; it was posted by jerr3d. It isn't the model itself. I can parent it to the head, and it moves along fine.
