Sat, Feb 8, 8:33 PM CST
Subject: tutorials for B5 to create twists, spirals and organic crescents
darknewt ( ) posted Mon, 14 January 2002 at 2:04 PM · edited Sat, 08 February 2025 at 8:24 PM
I would like to find a tutorial to create a spiral cylinders to use in set design and for ropes. Also I would like to create crescents that are completely curved and rounded with out using the terian editor. Is this possible to create the shapes I want with boolean objects?
Triarch ( ) posted Mon, 14 January 2002 at 5:13 PM
Booleans would work for the crescents, if we're both thinking along the same lines, but you'll probably want to check out the Multi-Replicate feature for ropes, chains, and the like. The multi-replicate tool seems to have been designed with that pretty much in mind.
tradivoro ( ) posted Tue, 15 January 2002 at 8:55 AM
You may also want to look at a freeware program called spiralizer... It will create great spirals, an dit's very easy to create things like a nautilus, seashells, and just strange stuff... It's at http://www.armanisoft.ch/webdesign/default.htm While you're there, grab elefont too...
Triarch ( ) posted Tue, 15 January 2002 at 10:07 AM
Wow! I checked that out. Thanks for the tip. Looks good. Hope it works better for me than Elefont has, though-- that's been hit-and-miss.
Sihn ( ) posted Tue, 15 January 2002 at 6:28 PM
This is great! Here's what I did...
darknewt ( ) posted Tue, 15 January 2002 at 6:54 PM
Thank you all! I will try it this weekend.
Triarch ( ) posted Wed, 16 January 2002 at 12:14 AM
This was a Spiralizer spiral with a stone column "inserted" into it? Looks easy.
tradivoro ( ) posted Wed, 16 January 2002 at 1:30 AM
Yeah, spiralizer rocks... Great results with little effort.. Very nice pic...
Sihn ( ) posted Wed, 16 January 2002 at 2:43 AM
One spiral, duplicated twice. The other two were slightly rotated in order to fill space and to add a second color.
howdydooo ( ) posted Thu, 17 January 2002 at 10:35 AM
You can also use 3D Studio Max if you have it. Creating two cylinders, grouping them and then stretch and twist. You have more control over the number of polygons by setting the number of sides for the cylinder which will give you your smoothness. Just my two cents.
tradivoro ( ) posted Thu, 17 January 2002 at 1:47 PM
Yeah, but howdy, spiralizer is completely and utterly free... 3D studio max is one of the biggest rip offs on the face of the planet... :)
howdydooo ( ) posted Mon, 21 January 2002 at 11:36 PM
I was only tryin' to help. Sorry for my input.
tradivoro ( ) posted Tue, 22 January 2002 at 1:20 AM
WEll, it wasn't meant that way howdy.. It's just that 3d studio max is a great program that is extremely overpriced and, of course, I'm sure it has features that would blow this away.. But this is just a little freeware program that can do some clever things... :)
howdydooo ( ) posted Tue, 22 January 2002 at 3:51 AM
Once again, I am sorry again. :(
