Vue F.A.Q (Last Updated: 2024 Sep 20 5:40 am)
Hi MikeJ . . . It's funny you've brought this up today, I was just trying it again this morning. No, it still doesn't work. I've tried several times, since owning Vue 4, & Vue 4.03, to do a Boolean difference with an imported object, ( even a very simple object ), but it just won't work. I end up with a very distorted final object. Maybe E-on will have a solution or fix ready for the next patch??? I hope. Heheheh. Have a good one . . . Mark. 8^)
Yeah, it's on a very recent official bug list which originated in the Yahoo Groups Vue email list. Using boolean differences on the terrains in Vue 3.1 was unpredictable at best, but still better than what I've seen in Vue 4. However, it doesn't surprise me about the trees and plants, because they are very unusual "objects", really, and not much like meshes.
Mike, If ever you need to "take off" a part of a dead tree, use alpha maps (and take off the part in your paint program). If you want to make completely invisible the trunk (and the branches)of any other tree, I have a tutorial for it. I use this when I apply vegetations to a wall, a roc or a terrain what should look like hanging plants. Guitta
Since it's been a while since it was brought up, I'm wondering if there is anyone here who can successfully do boolean differences with Vue 4 when using an imported mesh. It works just fine with Vue 4's primitives, but not at all with an imported mesh, and I mean even with the simplest of simple, like a 14 polygon cube. Not in Vue 4.03, that is. It works perfectly in Vue 3.1.
