A couple of things I thought I'd mention since I'm at it. I just opened Poser since I updated it and now the position of my document window ( or whatever it's called) is not were I saved it when I set the prefered state. The rest of the interface is saved just the window isn't. I moved it where I wanted it and closed it and Poser. The second time I opened Poser I got this message: "The requested window size is too large, creating the next best thing". Or something to that effect. What's that all about? Now I now why they say if it's not broke dont fix it!
I resaved the window smaller on a file and closed it and then started to make a new file and I get the same " window size too large message" again. I then opened my file with the smaller window and I get the message again. Somebody clue me in here. It seems that I'm getting this warning no matter what file I open. I'm going to bed now I'll check back and see if anyone know's what's up with this in the morning. Thanks, droyd
When the update is installed the programs menu gets changed from Metacreations to CuriousLabs. There's a bug there somewhere that leaves out the "start in" information for the short cut. Edit the short cut so that it looks for Poser.exe in the Poser 4 folder and your UI settings will stay set after that.
I'm on WIN XP now so I can't go through the steps for WIN95/98.
When I say shortcut, I mean the one you click in your programs menu: Start>Programs>Curious Labs>Poser 4
Edit the properties for this in the advanced tab of the Task Bar settings.
Find the "start in" box and insert the path to the folder where poser.exe is located.
Hi, I just installed the Poser 4.03 updater and I was wondering if the "Poser 4 Updater Save" folder it made on installation is important at all. Can I safely delete it and not worry about it or will Poser continue to use it and need it in the future. I realize I can probably just delete it but I thought I'd ask first.
