Thu, Jan 23, 1:02 AM CST
Subject: Path Problems...
berkeys ( ) posted Fri, 25 January 2002 at 9:35 AM · edited Thu, 23 January 2025 at 12:57 AM
Ok, someone please try this: Select a preset path, either
the oval or the circle, then attach a box and align to path.
Next, animate the box moving all the way around the path.
When the box reaches (or is parallel with) world Z, it
suddenly does a 180 flip on its Z axis. This is very frustrating. Am i forgetting something? thanks for any
help you might have,
berkeys
berkeys ( ) posted Fri, 25 January 2002 at 10:11 AM
I should add that the path needs to be geometric for my purposes. More than one object will be using this path.
Alleycat169 ( ) posted Fri, 25 January 2002 at 12:53 PM
It sounds like you need to delete a keyframe for the Z rotation at the point it flips. Set the box in the correct position and set another keyframe for it. Also, make sure you have the "Auto Key" feature turned off while doing this. It tends to add many more keyframes than you want for everything in the scene. You could also try creating your own motion path instead of using the preset path. It takes a little longer but you can at least be sure only the keyframes you make will be there. Good luck.
berkeys ( ) posted Fri, 25 January 2002 at 2:29 PM
Well, its definetly not the key frames theory, due to the fact that if you rotate the path on Y axis, the problem moves in relation to the path (or stays parallel to world Z. And this preset path was only an easy way for me to show what was happening, I am using a motion path that has been changed to a geometric path because i need more than one object on this path. But I appreciate your help just the same.
Alleycat169 ( ) posted Fri, 25 January 2002 at 9:44 PM
It is possible to set a keyframe for just the Z axis, you don't need to key frame everything in the scene. I've never seen anything like what you described unless an errant keyframe was set for one axis (or world as you say). Sorry I couldn't be of more help, maybe Corel tech support can.
GROINGRINDER ( ) posted Sat, 26 January 2002 at 12:31 AM
I don't know about B5, but in B4 objects turn around on the curves when they are too tight. If this is the case you need to smooth out your curve and make it looser. By that I mean increase the diameter. This happens on every animation I do and it happens with trajectories as well as paths. I had hoped it would have been fixed in B5.
